rear spoiler for my 68
Old 08-28-2012, 09:14 PM
mikes68's Avatar
Default rear spoiler for my 68
just got my spoiler in today will be putting it on this weekend any tips it came with a template so it should go smooth lol
Old 08-28-2012, 09:54 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
are you going to relocate the camaro badge like the factory?
Old 08-29-2012, 04:36 AM
mikes68's Avatar
didn't even think about that where is the correct place for the emblem with spoiler and thanks
Old 08-29-2012, 11:26 AM
Don't forget to put some sealer around the holes once you test fit it, and are ready to permanently bolt it down. I like non hardening duct seal putty.
Old 08-29-2012, 12:47 PM
The trunk lid that's designed to be used with a spoiler has pre-drilled holes, and larger access holes on the under side. Drill your stud size holes first, then you'll need to drill a larger hole from the back side to fit the nut with a socket through. You'll be bolting up inside a cavity where the reinforcements are, the studs on the spoiler aren't long enough to go through both layers of the lid. It'll make more sense once you start drilling and scoping it out.
Old 08-30-2012, 09:04 AM
dynarider33's Avatar
If your car was equipped with RPO D-80 (factory installed rear spoiler) then the trunk emblem was moved up higher on the deck lid. If your car was not RPO D-80 and the dealer installed the spoiler, the dealer removed the emblem and it was not reinstalled.
Old 08-30-2012, 08:12 PM
mikes68's Avatar
my car never had a spoiler
Dcapper81
07-27-2011 09:47 AM
Captainmugsy
05-26-2011 06:29 AM
endo
11-16-2009 09:22 PM
hurley870
03-06-2007 08:58 PM
sprice73
07-03-2006 03:32 AM
Quick Reply: rear spoiler for my 68
