67 water temp gauge issue
Old 08-25-2015, 03:51 AM
camaro396's Avatar
Default 67 water temp gauge issue
I recently installed a set of console gauges to my 67 396 and the water temp gauge is reading high. I'm not convinced the engine is running hot as when I turn the headlights on the gauge reading goes up slightly and when I turn them off it goes down slightly. Any suggestions?
Old 08-26-2015, 06:14 PM
77thor's Avatar
Bad sending unit?
Old 08-27-2015, 08:00 AM
You did install a different sending unit along with the gauge? The gauge won't work with the factory idiot light sending unit.
camaro396
08-09-2015 06:29 AM
CarolinaCamaro
02-24-2014 05:54 PM
SB60
01-11-2012 01:04 PM
bizarre660
10-04-2010 09:48 PM
josh95camaro
10-09-2009 10:15 AM
Quick Reply: 67 water temp gauge issue
