wheels and rims help
Old 03-04-2007, 07:15 PM
fasted's Avatar
Default wheels and rims help
I have a1967 camaro convertible looking at torque thrust polished rims what is the size if the car is not changed. how tall can i go also tires
Old 03-04-2007, 10:31 PM
pistolpete_67's Avatar
Default RE: wheels and rims help
I have a 67 also with the same torque thrust rims, I put on 17 X 8's with some 245/45ZR 17's on it. They work great and look great. Mine rub a little bit when I turn right on the bolt that connects the fender skirt to the fender on the passanger side, but I think that's cause something's f-ed up in my front end cuase it doesn't even come close on the other side. They should work for you, I'm not sure how much bigger than that you can get, but you probably can...
Old 05-05-2007, 12:23 AM
my1967kamaro2's Avatar
I have 2" dropped spindles I just put on. also got 17" X 8" torque thrust 2, fenders rub bad gonna have to change to 17 x 7 in front.
Old 05-05-2007, 10:39 PM
1969 SS's Avatar
look at some of the other tire size posts. there has been many good, and right, tire size combos posted in there many times
Old 05-06-2007, 01:00 PM
In the back I had a mono leaf before i changed it now it is a multi leaf stock I could probably put 18x8 in the back with 245/45/18 and put 17x7 in front with 235/40/17 and it would look bad a$$ if i could ever get a pic to upload i would show you a pic
Old 05-06-2007, 01:19 PM
OK I think I figured it out here it is
[IMG]local://upfiles/7826/03A8767BC6324FFC9E7C11605962F0C2.jpg[/IMG]
Old 05-06-2007, 01:27 PM
those tires are 245/45/17 like I said with 2 inch dropped spindles stock A-Arms 17x8 in front will not work maybe with out 2 inch drop they will here is a couple more pics
[IMG]local://upfiles/7826/9DA8DD6E22574257BB9CDF6C87ABC2AB.jpg[/IMG]
[IMG]local://upfiles/7826/67D55FAB2D864B6BB9BF58B83382A19C.jpg[/IMG]
Old 05-06-2007, 02:38 PM
74454bb's Avatar
May 2007 ROTM
What size TTD's do you want are you wanting a old school 15" rim or do you want the new 16- 18's ? I have the 15/7's front and 15/8.5 rear on mine.
Old 07-10-2007, 08:37 PM
Saint27's Avatar
i have a 67 vert with factory suspension, with 20's in the back and 18's in the front.
Old 07-11-2007, 10:58 AM
skar's Avatar
17 X 8's with some 255/45 in rear 17 x7 up front . (they are smaller then what I have in rear ? 215 or 225)(torque thrust 2)
no rub.
Quick Reply: wheels and rims help
