2015 Camaro SS, what size rim to run drag radials? help.
new to the site, new to the Camaro world....
I have a 2015 Camaro ss 1le, wanting to run it at our local track. I did some research but not still clear on what size rim to run. I gathered the smallest rim I can run is a 17" due to the large brakes. Any help would be appreciated. Plan on running a mickey Thompson et street radial, still not sure what size on these. wanting to keep it close to a 26" tall tire if possible.
thanks guys.
from what I have found, a 17x10 with a 7.5 back spacing may work? thoughts? is there a cheap ebay rim in this size that will fit?
thanks guys.
