2010+ V8 Tech For you LS3 and LSA guys to discuss modifications.
change rear gear help
Old 08-13-2013, 11:14 AM
evilcamaro's Avatar
Default change rear gear help
My rear end is starting to whine now and i think its because i have the turbos and it cant hold the extra power should i change the gears or whats a solution to fixing that
Old 08-13-2013, 11:18 AM
Cheeks's Avatar
August 2011 ROTM
either a 9" center section or a new set of gears
Old 08-13-2013, 11:45 AM
MKCoconuts's Avatar
I'd just find a new aftermarket rear. Might as well put something into that you know shouldn't break with the extra power.
Old 08-14-2013, 02:19 PM
evilcamaro's Avatar
Im thinking gears what gears i like the stock gears that are in it but do they make stronger stock ones ??
Old 08-14-2013, 04:44 PM
MKCoconuts's Avatar
They do, but strength is determined not just by material or manufacturing process, but it's diameter and even the ratio plays a part in strength. If I'm not mistaken, the 5th gens came stock with a 8.6in ring gear, which usually is more than plenty, even for a built up vehicle. But like Cheeks said, a 9in is basically indestructible and is the best option, if they make one for the 5th gen.
Old 08-29-2013, 07:41 PM
edog2's Avatar
May 2010 ROTM Winner
My buddy (pushing +600HP) went through several different gears. The only issue he had with any of them is that he stretched the housing and in turn pulled the pinion out enough to chip some teeth on the ring. The 2010 has an aluminum housing that didn't stand up to what he was putting down, the ZL1's is steel or cast or something stronger. The solution he went with was some kind of preload bolts that go through the whole thing to keep it from stretching. I dont know exactly what they are called though, maybe someone here knows.
Old 10-13-2013, 11:01 PM
bartman432's Avatar
Unfortunately, when you build one portion of the car, you gotta build the rest of it to handle all that power. In addition to building your rearend, I'm sure your tranny will need some attention. I had to do the same for my diesel truck. Built trans and upgraded rearend.
Old 11-15-2013, 12:19 PM
evilcamaro's Avatar
I really need new rear end gears where can i pick my self up a set that are strond and cheap
Old 11-15-2013, 02:30 PM
MKCoconuts's Avatar
Changing the gears will only be a temporary solution. Read this article:
Hendrix Engineering 9-inch Rearend - GM High-Tech Performance Magazine
Direct Camaro
70-81 Transmission & Differential
05-20-2015 09:21 PM
dynarider33
01-05-2012 06:04 PM
Chevy101
06-02-2011 05:17 PM
roscoe
09-08-2007 11:09 AM
95slvrZ28
06-07-2007 02:11 PM
Quick Reply: change rear gear help
