Transmission noise throw out bearing whine when cold
I have a 2013 1le 47k miles When the weather is 52F or under i get a sharper noise from the normal throw out bearing noise until the car warms up of course after driving 15mins plus after that only noise is the normal throw out bearing noise
sound link
sound link
Well yes is more like a stereo sound u know when u have that weird whine is not really noticible if u dont pay attention to the sounds is louder on the video i guess more detailed
Well i am pretty sure is coming from the tranny cause when i press the clutch it goes away and like i said the noise is faint nothing really loud at all is just the normal tranny noise with a faint whine to it
No the sound stays there even when i press the clutch gradually until it disengages i put it in gear make it roll and leave it in gear press the clutch in i can hear it faintly until i take it out of gear is weird and it annoys me maybe the input shaft bearing playing games? Smh
Keep in mind replacing a noisy bearing can be kinda of expensive, repairing a manual transmission after a bearing failed will be VERY expensive.
Sounds like something with the input shaft or possible with the counter gear bearing. You should get it looked at by someone who really knows manual transmission. If you are the original owner the car should still be under the drive train warranty?
I think the warranty has to be transferred or at lease that was the way it worked. If you bought it at a GM dealer they should handle it automatically. It has been awhile since I have done it but you can log into GM's website and check the warranty status. I am sure a dealer could tell you pretty quickly. A word of warning, they will not cover a clutch component under warranty. If you are covered you may want to ask them "what if" its the clutch.
