somethong off about my first gear n clutch
Old 07-19-2014, 01:36 PM
TheDevilsBreed131's Avatar
Default somethong off about my first gear n clutch
Ok so I've noticed something weird. And I couldn't tell if its my clutch slipping or not grabbing my first gear right, but basically when I put it in first and just try to do a gradual acceleration and give it a little bit of throttle, I feel like a kinda violent shake in my steering wheel and I feel it thru the clutch pedal as well..is my first gear going out orrrr any clue on what it might be? Haven't taken it in the shop yet but I wanna figure out what it is so when I take it in
Old 07-23-2014, 11:46 AM
STREETREBEL's Avatar
Is it a new clutch? Sounds like it might be clutch chatter.
Could just need broke in.
Or your flywheel may need re-surfaced.
Old 07-24-2014, 04:18 AM
No it's the same clutch that my cars had since I first got it. And it still runs like a beast. But the first gear worries me cause it shakes kinda hard. It's definitely been broken in though. How would I know if it needs resurfacing?
Old 07-25-2014, 08:00 AM
Here, I found this link for you.
Manual Transmission Clutch Chatter
A good shop will figure it out fast
Old 07-25-2014, 12:43 PM
One more thing that link doesn't cover is if you ever overheated/cooked your clutch from slipping it too much under power, you could have created checks (cracks) on the surface of the flywheel. Oops, I've done that before, and it makes for a nasty chatter.
Old 07-26-2014, 04:01 PM
Thanks I'll check it out..un****infortunately, my clutch went out last night. Or at least I think JTS probably what you're saying. Cause when I put it in any gear and brought up the clutch it made a horrific chattering grinding noise my poor baby.
3.4putter
01-28-2012 07:35 PM
tsdecker90
10-10-2009 07:56 PM
locotrician
05-16-2009 11:18 PM
Jamezzz
04-16-2009 07:02 PM
Pro_built7
04-10-2007 02:07 AM
Quick Reply: somethong off about my first gear n clutch
