Center console gauges
Old 10-10-2016, 11:36 PM
HeliMech's Avatar
Default Center console gauges
Is it possible/feasible to add the center console gauge pod to my '13 2LS? I have a 6spd car. I love the look of the gauge pod and I hate the mini cave in front of the shifter.
Old 10-29-2017, 07:28 AM
Shakadula51's Avatar
I have the same question. From what I have seen on youtube it is possible. I can buy the gauge pod from gmpartsdirect but need to figure out if it is plug and play or do I need to add the trans temp sender and oil temo sender to the pod. Anyway if I figure it out I will post again although I suspect after all this time you may have already figured this out.
Old 01-27-2018, 06:37 PM
Rombama's Avatar
it's super easy for 2012 and newer cars, all you have to do is buy the correct gauge cluster and put it in, all the wiring and sensors are already installed.. so the install takes about 5 minutes and no tools needed. I did it myself.... just take care to order the correct cluster.
miichielx
05-16-2013 07:15 AM
69SS427
08-19-2010 06:06 PM
ashleythomas15
12-19-2006 02:12 AM
onefast71
12-11-2006 05:35 PM
Charles_M
10-22-2005 11:28 PM
Quick Reply: Center console gauges
