warranty question
Old 07-26-2011, 08:56 PM
Polaris Man's Avatar
Default warranty question
Does a K&N cold air intake void any warranties?
Old 07-26-2011, 09:44 PM
You should ask the car dealer or a factory rep. Regardless what any one tells you, the factory makes the rules as far as warranty is concerned. If you are just changing the filter element, it should be no problem, but if you are altering the intake plumbing they may give you a hardtime if they feel that was what cused the problem.
Old 07-26-2011, 11:11 PM
edog2's Avatar
May 2010 ROTM Winner
It voids the warranty on the air filter, since it is gone. This comes with the K&N, the second para is the good one.
Old 07-28-2011, 01:11 PM
Chevrolet Customer Service's Avatar
Official GM Representitive
A K&N Air Intak kit can harm your warranty. GM's stance is that any changes to the vehicle that would result in the vehicle not being the same as it came from the factory would constitute as a modifaction and would then possibly cause your warranty to be voided. If you modify your vehicle I would check with your dealership before hand to make sure that in case you have an issue they would be willing to help you. I hope that helps to answer your question.
Jeff Morris, Chevrolet Customer Service
evilcamaro
09-13-2013 01:12 PM
belliott
03-08-2012 01:26 AM
pcarollo
12-03-2010 09:42 PM
Simbad66
08-05-2010 04:58 PM
MrNah
12-14-2008 04:34 PM
Quick Reply: warranty question
