Airbag Light & Service Airbag message
Old 09-01-2013, 08:31 AM
edog2's Avatar
May 2010 ROTM Winner
Default Airbag Light & Service Airbag message
So my wife got a brief airbag fault a few months ago, but it was gone next time I started the Camaro. It came back on for me about a month ago and has been on ever since. Dealer says to replace passenger presence module ($416+$300ish labor). I called Chevy since I personally think the airbags should be covered a little better than bumper to bumper, especially after seeing on some other forums that this is a little common. They are working with me, but I figured I should try and share some info on the issue here just in case. I found the following TSB's and something called a PI (which I should find out more about Tuesday). It is interesting to see the PI says NOT to replace the PPS/SDM when the codes given are found, guess which codes I have.........
2012
PB-12065 04/01/2012 10044223 Chevrolet: see document search button for owner letter. airbag warning light may illuminate due to software issues in sensing and diagnostic module (sdm). *pe2012-05-23
2011
PI-0241 09/01/2010 10036025 Chevrolet: sir/airbag indicator/light on in the instrument panel cluster (ipc); dtcs b0074 and b0081 set. do not replace the passenger presence system (pps) module or sensing and diagnostic module (sdm) for this concern. *pe2011-03-07
2010
SB-10-09-41-001B 02/01/2010 SB-10-09-41-001A 10034406 Chevrolet: diagnosing and repairing airbag readiness light (sir) illuminated (reprogram inflatable restraint sensing and diagnostic module (sdm)). when diagnosing the condition, the technician may find dtc b0079 sym08 or dtc b0080 sym08 s2010-11-10
This is were I found the info above:
Chevrolet Camaro 2010 - Air bags - car safety information, failing parts, recalls, bulletins, complaints
Socom
12-09-2012 08:15 PM
ESPxCONxXx
03-22-2010 02:12 PM
irocktheIROC
01-04-2010 06:37 AM
golfballs
08-04-2008 10:46 AM
Quick Reply: Airbag Light & Service Airbag message
